Hyper Milers dont use BRAKES! lol
Originally Posted by mcrews
pete said: "[B] I figure the added wear on tranny and axles is easily offset by the reduction in rpms/engine life. [B]
The real concern is in the small stuff. bushings and brakes.
But with the majority of your driving being highway you probably don't need to worry
the tires weight about 3.5 lbs more and the 15 rims about 4lbs.
So you at 7lb x 4 = 28lb of moving extra weight.
the old set up was about 125lb moving and the new is around 148lbs.
I am aware of the added unsprung weight and the increased inertia to get things rolling.
There was a very detailed thread on Toyota Nation regarding the effect of larger diameter tires/heavy wheel-tires.
What a day, drove down to NYC, worked from 11:30 to 8:30 and drove back home to Maine. The summer repaving has started and there is road work all over the place. Lots of traffic jams. Took 5 hrs to get down and 5 hrs to get back.
Scangauge says 35.9 MPG. Will fill up tomorrow as
today my new Full Moon Racing Hupcaps came from Hupcap King!
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
