On my car foot off the accelerator TPS=9 and it does Fuel cutoff in 3,4,5 gear if RPM is high enough.
On scangauge in SETUP/FUEL/CUTOFF I say TPS=10 for cutoff and the scanguage shows cutoff (MPG=9999 and GPH=0). If I set the scanguage cutoff to TPS=9 it does not read it.
So my advice set scanguage to read cutoff at one TPS higher then foot off accelerator TPS.
