Old 06-05-2010, 12:45 AM   #7 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
bad idea , do not do it
bad idea
fuel is about 1 15th of the Mass of the air fuel mixture prior to combustion assuming the engine runs at or close to stoich or Lambda of 1 ,
heating the air will have a much greater effect
and
heating the air has been experimented with a whole lot in the pages of this forum
so you can read up on the success or lack thereof of current and past experimentation regarding WAI
you can learn from the pain of others , if you have your wits about you and make your own informed choice
those who will not learn from the mistakes of history
are doomed to repeat them
Originally Posted by bandit86 View Post
I wasnt thinking direct injection, just a regular fuel injected gasoline engine
..."I suppose that's better than heating the fuel line with a bonfire."...
yes .
Last edited by mwebb; 06-05-2010 at 12:49 AM.. Reason: I suppose that's better than heating the fuel line with a bonfire.
