Old 06-05-2010, 03:37 AM   #1 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Bridgestone Ecopia EP100
Hello -
Saw a commercial for this and was curious :
The Ecopia EP100 is one of Bridgestone's ecologically oriented Grand Touring Summer tires developed for coupe and sedan drivers looking to combine traction, handling and comfort with reduced environmental impact. Ecopia EP100 tires are designed to enhance vehicle fuel economy by reducing tire rolling resistance along with the vehicle's carbon dioxide (CO2) emissions during operation. The Ecopia EP100 is designed for dry and wet conditions, but like all summer tires is not intended to be driven in near-freezing temperatures, through snow or on ice.
The Ecopia EP100 employs a tread compound that applies Bridgestone's unique NanoPro-Tech (Nanostructure-Oriented Properties Control Technology) to reduce rolling resistance and energy loss while maintaining wet traction. This compound is molded into a symmetric tread design featuring rib-linked blocks nestled close together to provide uniform footprint pressure combined with high-angle, lateral grooves to further enhance braking in wet conditions. The tire also features three-dimensional (3D) curves on the tread block surface to suppress noise generated when the block is in contact with the road.
The tire size/specs seemed limited (only one rated at 51 PSI), but the tread is intriguing and I always like Star Trekky words like NanoPro-Tech.
CarloSW2
American Solar Energy Society
