Hey Paul!
I'm finally making some progress. I got the control board together, did a 12 volt test and things are working great - both LED's on steady! (You have to connect RT1 and the LEM, it took me a while to figure that out.) It's all assembled except the enclosure. I have some work to do on the vehicle before I can drive away but it's coming along pretty good now.
Quick question on the trim pot for current limiting. All the way clockwise is 775 amps. Is all the way counter-clockwise 495 amps? If so, that's probably where mine will live.
John
