Old 06-06-2010, 02:55 PM   #10 (permalink)
ShadeTreeMech
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
Originally Posted by Arragonis View Post
I feed mine the VW spec 505.x (I think thats the spec) synthetic oil and at the moment it uses non between changes which is why my I looked elsewhere for my recent turbo smoke than worn parts. Luckily my gaffer tape / turbo boost pipe fix seems to have cured it.
I suspect the smoke you were seeing was as result of lost boost pressure--the boost pipe you fixed was on the pressurized side, correct? Assuming that, the smoke was likely unspent fuel the engine injected while expecting full boost pressure. Hence the reason naturally aspirated diesels tend to be a bit smoky; the extra air helps to burn all the fuel.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
The Following User Says Thank You to ShadeTreeMech For This Useful Post:
Arragonis (06-06-2010)
