at least two variables
..."had a small cam advance (2-4 degrees) when he had his head shaved "....
when he had his
"head shaved"
he also INcreased his compression ratio as well as the small valve timing change
so
just a slight valve timing change
alone
may not / will not provide the same results / improvement
