Old 06-08-2010, 08:12 AM   #6 (permalink)
Daox
I personally watch the LOD (engine load) more than any other gauge. However, the scangauge also can read the coolant temp which is very useful in winter, and I also use the 12V quite a bit as I have an alternator disable switch.
For a belly pan, air can still go out the wheel wells. Nothing under the car needs cooling really, but I'd be careful with your pan around the CAT.
The Following User Says Thank You to Daox For This Useful Post:
slowmover (06-13-2010)
