Old 06-08-2010, 08:39 PM   #3 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
1. It's better to blip the throttle to approximately rev match. It will save wear on the synchros.
2. There's no single answer, aside from accelerating at or near optimal engine efficiency. Wide throttle increases engine efficiency, but if you go too far, the ECU will enrich the fuel:air mixture. A ScanGauge is helpful here.
