Originally Posted by RobertSmalls
1. It's better to blip the throttle to approximately rev match. It will save wear on the synchros.
2. There's no single answer, aside from accelerating at or near optimal engine efficiency. Wide throttle increases engine efficiency, but if you go too far, the ECU will enrich the fuel:air mixture. A ScanGauge is helpful here.
Originally Posted by Turbo Dan-O
Yea, speed matching will be better on your trans and clutch and also not slow you down any. As for throttle.....I am still trying to figure this out....
Dan-o
I haven't been doing the rev-matching though I kept thinking that I should since that's what I've always done when down shifting. Now I know and will start my blipping again!
I do have a SGII and I know that if I keep the "LOD" down below 86 I will stay in closed loop mode. Through a little in-town driving today, I have managed to repeat my WOT LOD at 78 almost every time, if not just a tad below.
Thanks guys!
