Originally Posted by PaleMelanesian
I'd support this only if it's an additional mark. %EPA is a comparable standard to measure all the cars against. What if I set my mark at 10mpg? I'd be... 578% above!!!
All the cars? Actually only models sold in the USA are EPA rated. My EPA number is actually inferred on the U.S. version but the model is unique to Canada; Transport Canada figures don't always translate to EPA. We also have people here from outside North America? What do they use? Some drive cars that aren't sold here. Heck, some Canadian models aren't sold in the USA like the small Acura, the gen 1 Smart cars etc.
Comparable? What does measuring against EPA compare? How you compare to an artificial test, right? So if you are better is it because the rating is easier to beat for your particular make and model? We all know how much difference the type of transmission makes yet the EPA ratings for automatics are often higher. Or maybe because you try 100% and your techniques are excellent? Maybe because you cherry pick your drives? My commute is my worst possible mileage scenario so any other trips help my mileage. Perhaps you live in Florida where gas is always summer grade equivalent, the bearings and fluids don't get cold and the roads are flat?
Likewise if someone does worse than EPA, is it because they live in WV at the bottom of the biggest hill you can imagine and take shorts drives or do they like passing everyone on the road?
I guess I don't share the same fascination with exceeding EPA numbers that many of you do. I live in a climate that's cold half the year and commute very short distances and do lots of other short haul stuff with kids as well.
My goal is 23½ MPG / 10 LHK. That's what I measure myself against. That's why I bought a ScanGauge, that's why I try to use forums like this to help me achieve my goal.
Anyway, the hosts here do an amazing job. I don't want to add work for a fringe request. Just remember that EPA on my sig stands for expected pump average. My "epa" rating exceeds the inferred U.S. "EPA" rating by 25%, hopefully I can achieve it.
