Old 06-09-2010, 10:55 AM   #2 (permalink)
PaleMelanesian
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
There are several options here.
- Fill up to the rim of the filler tube. That way you know it's full.
- Adjust the Scangauge to the average fillup. If it says 10 gallons and you put in 11, adjust it to 10.5. After a couple tanks, it'll average out pretty well.
- Keep a log with the SG readings and pump gallons. Calculate a running average offset and use that. I use this method, with a 12% offset (more gallons, less mpg compared to the SG default).
The Following User Says Thank You to PaleMelanesian For This Useful Post:
Imatech (07-09-2010)
