Old 06-09-2010, 05:38 PM   #1 (permalink)
tollo
Alternator delete stuff and testing...
First warning: I think this is going to be quite long story...
I've been thinking about deleting alternator and running my car mostly with batteries. I made first testings to find out how long I can get with my standard battery. It is basic Varta 60Ah 12V battery.
The car is opel (vauxhall or holden) astra caravan (estate?) 2001 with 1.6liter engine. Deleting alternator is easy: I just lose the pulley with 15mm key and take the alternator belt of. (Water bump is with timing belt) About 30 sec job to take of and minute job to put it back.
I charged the battery with exide plug in charger to ensure that my battery is full loaded. My target was to get about 125km (78miles). SG2 showed battery voltage and this kind of tables:
helped to estimate how long I could go. With clamp ampere meter I got that car uses something about 20amps when running daytimerunninglights and other necessary instruments. With xenon lights and wipers I easily get about 40 amps and peak values with powersteering almost 100amps (I think that power steering is biggest ampere eater)
I started my testdrive and after couple of kilometers voltage leveled to 11.9 volts. I drove about 60-90km/h. After 120km (1h and 45 mitutes) I had 11.2 volts and I came to crossroads to turn left. When cornering the powersteering bump started running and voltage went down to 9 volts. ABS and airbag went off but car was still running. I continued and hope to get last hill up. Voltage rised slowly back up and ABS and airbag started work again. I turned the motor of and rolled last kilometer.
My bigger plann (just planning at the moment) is to put about 300Ah of lead acid batteries to my car. (enough ?) Most of them would cover the sparewheel. I could use plug in charger and batteries should last less than 4h of driving. In very bad weather (cold, dark and raining) I could put the alternator belt back on. Smaller plann is to drive only short (less than 50km) drivings (city) with basic battery and but the belt on to longer distances.
I think that batteries would last about 8 years (or more). How so long? No need to drive batteries totally empty and using quality charger won't charge with too high voltages. Too high voltages make batteries to dry. Extra batteries should be AGM or GEL because of the safety reasons. Most batteries die because of:
1. too high charging voltage
2. too deep discharge too long time
3. mechanical shocks
Fuel consumption goes down about 10%. My present consumption is about 5.7 l/100km and alternator takes about 0.2 to more than 1 l/100km mostly depending driving speed (30km/h-120km/h) and amount of electric equipments. In my case at least 0.3 l/100km (80km/h constant speed) to 0.6 l/100km (50km/h city driving).
... to be continue ( I hope ) ...
