[QUOTE=Old Mechanic;178620Instead I would do some research into the difference between the stock 94 Civic and the VX flywheels, which would give you a fairly good idea of what Honda did to get the best mileage possible.
regards
Mech[/QUOTE]
Oooh, great idea, i'll have to try and research this, may be difficult though.
At any rate keep the good info coming. What I might do instead of putting the vx trans in first with the stock flywheel, I may put it in with the light one, that way if all this info does point towards heaver ie 16lbs ish is best, then I have one less trans swap to do.
![Smile](/forum/images/smilies/smile.gif)
