an E-fan got me 2 MPG on my 4.0 v6. Well worth the money. Felt like i had more power, and after i got used to that the fuel economy went up. Quite easy to install most kits. Plus it is so much safer if ever tooling under the hood with the engine on. You are less likely to stick your fingers into and aftermarket fan as the enclosures have smaller spaces, unlike most factory ones that i've seen are more open
Randy
