Old 06-12-2010, 12:33 AM   #40 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Oh, and a few notes from a guy who just (450 miles ago) went from a Single mass flywheel (19 lbs with clutch bolted on) to a dual mass flywheel(52 lbs with clutch bolted on).
1) I can run 100-150 rpms less with same load.
2) Starting is much smoother.
3) bump starting is now effortless vs cumbersome (could never do it with picky passengers)
4) idle is much more quiet
5) other drivers are much more apt to drive it at lower rpm's than they were before (small sample size of 2).
6) shut down is now smooth and silent.
Best sum it up is smooth, smooth, smooth.
EDIT: as an FYI: I thought I had a DMF to begin with . . . . previous owner swapped it (apparently)
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
The Following User Says Thank You to dremd For This Useful Post:
fidalgoman (08-14-2013)
