Originally Posted by Daox
As long as you're confident in your setup you shouldn't have any problems. The most you'd loose is the turbo.
You're saying this like it's cheap and easy to replace a turbo.
Originally Posted by Old Tele man
...or "add" an electric OIL pump to temporarily take over whenever the engine's OFF and coasting...possibly wired to a driver-controlled switch?
You could modify a "
turbo timer" to control the electric pump. It's goal is to keep an eye on turbo temps and when it's needed to run the engine longer (or in this case, electric pump) to keep oil pumping to cool them down.
