Originally Posted by autoteach
well, that mass*velocity is linear inertia. Distance from the center for a rotational object has to be considered. You could produce a flywheel that weighs 20lbs that has the same inertia as ones weigh 18, 15, or 5 lbs.
Excellent point! I totally forgot about that!
Also what exactly is a DMF and where can I get one
