Old 06-12-2010, 12:07 PM   #60 (permalink)
usergone
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
Why not go low-tech, instead of keeping the ECU?
I had the idea of a "throttleless carburetor." It is just a throttle body with 2 jets. The jets meter their fuel by means of a tapered needle that pushes in to slow (or stop) flow, and pulls out to increase flow.
One needle has the gasoline, so whenever you push on the "go pedal" (sorry, I guess that in this application it really would be the "gas pedal") the gas needle opens. The other needle is water. It would be somewhat inversely proportional to the gas needle, so if the gas needle was almost closed (idle) the water would be injecting a good amount. If the gas needle was open (IE, flooring the pedal) the water would be injecting very little.
The water and gas would both have to be pressurized, so that you don't care about the Bernoulli effect sucking the fuel (and water) out, like a normal carburetor.
