Thread: Seventh Gear!
Old 06-12-2010, 05:10 PM   #1 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Seventh Gear!
Finally got around to putting my money where my mouth is, and installed a Gear Vendors overdrive on the Red Baron. Just did a test drive and still have a couple of small installation issues to work out, but this is gonna be sweet.
1125 RPM @ 60 MPH EGT: 475 degrees pre-turbo.
I also did some other work - chamfered my swollen brake pads, set camber and toe-in dead on zero, and I'm trimming back the air dam, so I'll need a month to re-baseline the truck's MPG. Then I'll get a valid 1500 mile test on the MPG.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
DieselFan (09-01-2011)
