Old 06-12-2010, 09:11 PM   #26 (permalink)
b939625
Import Tuner
Originally Posted by crexcrex View Post
I can readily see that inspite of countless experiments with vortex generators that this issue refuses to die a graceful death. Voretx generators do not work unless you are a delta winged fighter plane in the attack mode.
Vortex Generators do not work but the subject persists and it is probably due to various companies selling these easily knocked off plastic wedges for ridiculous prices.
Go ahaed and buy these ludicrous items whereas you can be putting the hard earned cash to work by filling your tank.Have you seen any high mileage vehicles using vortex generators? i hardly think so and if they did work i hardly think your vehicle or anyones elses can do mach 1 0r two...................good luck...........your loss is airtabs gain.
because it will take me a million years to explain this all,,,,heres the data !!!! plus its a good idea to research everything that goes with this subject matter..... Fluid Dynamics, Reynolds numbers, Bernoullis Principle, Laminar Flow and so on......
Vortex generator - Wikipedia, the free encyclopedia
(video)
(scientific explanation ) http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
(scientific explanation/experiment) http://iopscience.iop.org/1748-9326/3/1/015006/pdf
(good explanation) Vortex Generators for Enhanced Aerodynamics :: Sigma Automotive
Vortex Generator
(scientific) http://www.efluids.com/efluids/pages...G-5001129B.pdf
Vortex Generators - A Neophyte's Track Blog
Micro Vortex Generators - Over 500 Models of Aircraft Certified
Vortex Generators Aerodynamics from Aircraft Spruce
