Actually, the bracket you see with the wire wrapped around it is on there very tight. The wire was just to hold it while the JB cured. I have not tried to break it off yet, but I suspect I will need a big hammer
And in post 34, I meant on the shaft side of the U-joint, to the left of the bearings. I don't think the shape is very good just to the left of the bead of JB-weld, it has an odd profile (like a rectangle that has protuberants on the middle of the long sides)
