Old 06-14-2010, 01:12 AM   #63 (permalink)
autoteach
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
I have a few questions that will make either sense or someone pissed, but if anyone can already tell, I dont care about THOSE results.
1. Why are you trying to run throttleless? To me this seems sort of, well, dumb. Pumping losses are not much of a concern at anything less than full throttle (unless I am missing something)
2. Why regulate fueling with throttle position resistance? Would fueling just be easier to modulate with tricking the computers 02 input? (pretty sure the answer is yes, hopefully you can see that)
3. How are you reading EGT's? If you aren't, shame on you?!
4. If you are looking on how to run serious lean burn, why haven't you looked into modifying a stratified charge engine with a more aggressive egr and different injector nozzle sizing with water injection?
5. HCCI? I believe the manufacturers are working on lean burn...
6. Grab a VVLTi engine and control the valves to suit your needs?
7. Emissions are a tricky deal, how important are they in your project?
