Old 06-14-2010, 06:24 PM   #20 (permalink)
Gas-x
Gas-x's Avatar
Originally Posted by PowerHaus930 View Post
What do you think this car could do? i was thinking max of 50mpg but i'm not sure. Like I said I have the tire pressures up to 39psi (44 max sidewall), a hot air intake (how much above ambient is yours? do you use the resistor in place of IAT?), and the engine cut off switch. What would be the next best upgrade you think? I was thinking vacuum gauge and/or MPGuino. What about aero mods? what are the most beneficial aero upgrades? Thanks so much for your help!
Do you have a couple of pics for me? One would be the engine shut off and how it helps you and the other would be of the warm air intake and if it needs to be monitered for temp or not. thanks so much in advance. I am looking for ways to get a few more mpgs out of my 06 Aveo 5spd
