Thread: Cheap DIY EFIE
Old 06-15-2010, 10:40 AM   #9 (permalink)
pgmomni
Camry MPG Modder
Camry CE - '00 Toyota Camry CE
90 day: 36.18 mpg (US)
My thoughts exactly...
Originally Posted by mpgx2 View Post
What I am working through at the moment is combining
water-injection with lean burn.
I am led to believe that one third of fuel is used as an
internal combustion chamber coolant.
During combustion, it's the vapour that explodes and
the fuel liquid is just exploded and sent to the cylinder
walls to cool them.
If you go lean, you are just reducing the fuel component
that was destined for 'cooling'. That's why everything
'goes hot'.
Apparently, you can substitute that fuel for water and
it will achieve the same effect.
My Camry's AF ratio gravitates to 14.53 constantly. Drive me crazy. Only time it gets above 14.65 is for a few cycles when you let up on pedal to start a nice coast. After a few seconds ECU gets its right quick back to 14.53. I believe it has to do with drive-ability and durability.
Water injection I hope would allow leaner ratio and cooler combustion temps.
I need to search for a good how to build your own water injection as the commercially available systems are too expensive.
Pete
2000 Camry CE 5 speed 128+K. Best 37.0, Goal is to break thru 36 consistently(Attained). New Goal 38.
ScanGauge II, Unibrow(1 wiper) Air Intake, Mud flap delete, 3.5+" Front Spoiler, Full Moon Hubcaps(Lost). Upper Grille block. (New and improved Fall edition)
