Check and clean the grounds on the coil pack I believe that it should use the mounting plate for the ground. Also check for a vacuum leak using TB cleaner when the engine is running.
Does it misfire under certain conditions or can't you tell?
It could also be dirty injectors or since the timing belt broke it may have damaged one of the valves slightly a compression check should help to confirm that.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
