Old 06-15-2010, 05:42 PM   #5 (permalink)
ChopsQube
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
Originally Posted by DonR View Post
If you are unsure, I would consult the manufacture of the devices.
That being said, I would guess, guess they should go in front of the trailing edge that you are trying to minimize airflow seperation over. The distance in front of that edge & the spacing, I would assume to the the same as on a regular car.
Hope they work for you.
Don
That's what I'm thinking too, just the normal location like on most vehicles. Thanks!
Originally Posted by cfg83 View Post
ChopsQube -
Did the VG's come with instructions or did you make them yourself? You can see instructions for the airtab gizmos at airtabs.com :
http://www.airtab.com/vm/newvisual/a...tallV78pdf.pdf
CarloSW2
I didn't make them, they are made by Vortekz and come with instructions. However, nowhere online can I find anything about mounting them on a car like mine or an xB, etc, etc where the rear window just drops almost perfectly vertical.
