Old 06-16-2010, 07:12 AM   #9 (permalink)
Daox
I'm not sure what you mean when you say "read the OBD2 code for cylinder balance". I get a P0300, thats it.
I am using the 05 injectors since the fuel rail stayed attached to the vehicle while swapping engines.
All connectors matched up just fine.
I haven't done any compression/leak down testing. It seems to have plenty of power.
According to obd-codes.com:
A code P0300 may mean that one or more of the following has happened:
* Faulty spark plugs or wires
* Faulty coil (pack)
* Faulty oxygen sensor(s)
* Faulty fuel injector(s)
* Burned exhaust valve
* Faulty catalytic converter(s)
* Stuck/blocked EGR valve / passages
* Faulty camshaft position sensor
* Defective computer
