Old 06-16-2010, 12:18 PM   #89 (permalink)
usergone
I have to start over?
Big inefficient truck - '94 Dodge Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Honda Civic DX Hatchback
I suppose I should "clarify the idea" in the last post. What I am trying to accomplish in the above post is...
The current supplied to the injector is converted to a voltage, by means of a shunt. The voltage difference across the shunt will be called voltage A.
If voltage A is less than X, but greater than Y, a 0 to 12V signal is supplied to the guino.
X would be to cut off the top current from the "peak," and the Y is to set a threshold for what constitutes the "hold" part of the injection cycle.
