Old 06-16-2010, 02:45 PM   #6 (permalink)
Whoops
Whoop's Wheels - '89 Honda Civic Wagovan
90 day: 39.09 mpg (US)
If you are going to use the 8" wheels, then you would be wise to fill them to the highest possible inflation amount, they will handle. You want to get the pressure high enough that the sidewalls won't flex, which in turn causes the tires not to build up as much heat, internally, which in turn leads to a lot fewer problems with blown out tires.
Good traveling.
