Originally Posted by Arragonis
YKYAEMI you refuse a test run in your boss's new Supercharged Range Rover because you might hurt his current tank's MPG.
*(He uses more in a day to/from work than I use in a month)
...or when you are worried you may throw the numbers off to the high side!
