thanks for the info on the grill blocks. I've been using a obd data logger program, and one thing i found is that my temp gauge on the dash stays at 190 degrees, even though the obdii says the coolant temp is anywhere from 170-200 degrees.
i secured the fiberglass material to the existing louvers with screws.
