FE will DEcrease
Originally Posted by steve-o
i am thinking of trying to find some narrower tires for the paseo, i am thinking that a set off of a tercel will bolt right on. if i have on 185/60/14's on now and go to a 155/80/13 what can i look for in mpg gains?
the "gains" will be measured in negative Numbers.
and
do not forget to recalibrate your speedometer / Odometer against a GPS for speed and against highway mile markers for distance
use the recalibration for calculating FE per tank
it (FE) will get worse
Reason: i am from ny
