Make of it what you will, those are the results I got. I'm assuming that the boost affected peak torque and the exhaust simply kept the peak going for longer. Which makes sense...
Incidentally with my boost controller, the exhaust raised peak boost, but only by 0.5 psi or so. This had to be put down to to pre-exhaust levels to aviod hitting the boost cut.
