Old 06-19-2010, 08:46 PM   #5 (permalink)
gone-ot
...beats walking...
...don't get me wrong, I'm not disputing your results!
...just saying that increased boost, sooner in the RPM curve, produces BIGGER results sooner, but typically doesn't change top-end velocity...unless the additional boost is also maintained higher up the RPM-curve (dangerous).
...available HP and vehicle aero-drag are what limit top-end velocity. But, if the engine can produce more HP at a higher RPM, then the upper MPH limit will be increased, but only slightly because aero-drag is a cubic-functon of velocity.
