Oh now I understand, how load or map will help with acceleration whereas instantaneous mpg wont help, at least not directly.
Does the OBDuino read the injector pulses for accuracy or does it rely entirely on OBD which i heard is less reliable.
How much does the obduino cost and is there a kit? I can solder surface mount if need be. Money is tight right now so if a save a few hundred over buying two scangauges i'd be happy.
Hmm daox, it did not occur to me that i could put a connector on a mpguino and switch it in and out of a vehicle like i would able to do with a scanguage or obduino.
