Coming back to the original question about the lights, how about a foot switch ? Old Minis used to have the main beam / dipped headlights controlled by a foot switch instead of a stalk switch and that worked reasonably well. If positioned correctly you could press it instead of the brake pedal but you would need to make sure your foot didn't rest on it. Also it may be easier to add to the brake light circuit if it is close to the existing switch on the pedal assembly instead of reprogramming something.
