The redesign was focused mainly on appearance and visual impact.What ended up happening was that when the visual AH-HAH moment arrived I found the angle of attack of the upper surface was reduced from 7 to 3 degrees.Common sense tells me that this will result in less drag.Wouldn't you agree ? I have no way of putting a number on it at present.
