The biggest change on the Holden Commodore from the 3800 Series II is that the Holden ecotech was OBD-I even though GM did not make the Series II with OBD-I. (It is possible that the L67 or 3800 SII supercharged did use OBD1.5 in the 1995 Bonneville change over but I'm not %100 on that.)
I have found the programming for the Ecotech 3.8 v6 but being OBD-I i think will make it harder to locate the lean cruse portion of the code. I guess its time I start to learn assembly.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
