Old 06-21-2010, 06:57 PM   #17 (permalink)
Baggage Handler #2
Boris - '04 Saab 9-3 Linear
90 day: 22.75 mpg (US)
Natasha - '10 Saab 9-3 Combi 2.0 T
90 day: 24.42 mpg (US)
While I don't have any reason to doubt that your MPG is up from before, I don't think the reason is that the ECM was fooled.
The Mass Airflow Sensor tracks the air mass passing by it - pressure, temperature, volume, and presumably humidity are already accounted for by it. The location of a restriction upstream or downstream from it should not affect the mass of air passing it by.
In the sense that you no longer have a wide open throttle, it does in a way simulate altitude.
However, Boyle's law will not be denied and the restriction will require extra energy to compress, accelerate, decompress, and decelerate the intake air around it.
