06-21-2010, 11:21 PM
#30 (permalink)
apples and bannanas
Originally Posted by greenfuelbooster
I am moderate hypermiler since Aug 2008 .... My max was only 40 MPG even though I tried to push it. Using this configuration I get at least 45 MPG all the time. The restriction after the MAF gets me 44 already but with less power. The hydroxy gas injection adds power and the rest of the MPG. If you are in the northern VA/DC/MD area we can drive the test route (central MD to central VA) so you can see
You might want to check this PhD study. This might probably explain the hydroxy side.
4shared - free file sharing and storage - share folder - My 4shared
you MAY NOT use this paper / PDF to justify your.... claims
or shall i say ($700) HOAX ?
because
the paper refers to the test results showing benefits of HYDROGEN injection into a lean burn single cylinder engine.
but
you claim to be using HHO called by you HYDROXY otherwise known as browns gas .
it is NOT HYDROGEN it is two molecules of hydrogen with one molecule of 0xygen AND what ever clings on left over from the process you are using for electrolysis . ..
Hydrogen works, HHO does not .
apples and bannana s
