Old 06-22-2010, 02:00 AM   #58 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
An apology if someone has covered this one.
I understand that when the Deepwater Horizon fell over,it was then that the pipes were ripped apart from the blowout preventer and the actual rupture occurred.Is that correct?
If it is,should an explosion/fire occur on another platform,is this basically the failure mode? A collapsing platform?
Is there something inherently lacking in the fundamental design of the platforms?
Is 'worse-case-scenario' still part of mechanical engineering lexicon?
From what I understand, there is a device that crushes the pipe closed in an emergency, but it failed. There's some finger pointing about who's responsible for what, something like: the rig was built by one company, the hole drilled by another, the plumping done by yet another, someone else was taking care of the safety devices, etc. etc. It's not our fault, it's their's.
The Following User Says Thank You to Piwoslaw For This Useful Post:
aerohead (06-24-2010)
