Hi Bruce,
If you want better highway MPG you can do it for less than $20 ... Just find a way to force the fuel injectors to use less fuel. I found out that mimicking high altitude driving does that. You can try #1 on the link below ... It worked on my 06 civic ... hopefully it will work for your car ... It requires hypermiling driving habits .because you have to live with lower engine power than you are used to now.
Originally Posted by brucey
Can it be adapted to any car?
I'll bite, I'm in Martinsburg WV/ Haegerstown MD everyday.
