Old 06-22-2010, 08:39 PM   #39 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by mpgx2 View Post
Phantom, you have an amazing wealth of information.
To run mine lean, I will replace the O2 sensor with an EGT
sensor and then work on leaning out way beyond the 20-30%
boundaries set by the ECU.
My target is to even try down in the vapour range at about
10%. Eventually...
If you get too lean and it runs you tend to get detonation, although it may not make tons of heat it will blast little pockets in your pistons
