Old 06-25-2010, 12:33 AM   #3479 (permalink)
ChedMpls
Bus Bars to PCB
Back in post 3399 mcudogs talked about putting copper bus bars, solder, and PCB into an oven to solder them together. With this method would i need to tin the bars and board first? A different method he mentions requires tinning but the oven method didn't specifically mention it so i'm really hoping i could skip a step and still get a solid connection. i'll probably try this with some scrap copper pieces but i'd love some input before i stick my actual parts in the oven!
I'm ordering parts and want to know if i can save $23 by skipping silver filled epoxy.
btw.. how would i send a reply/ message to just one person in this forum? i wanted to ask mcudogs this question without ELONGATING the thread! didn't see an email in his "contact info"
about backordered parts from digikey - i went with part# P11621-ND which is a 2" tall power cap and i plan on using a 2" tall aluminum heat spreader bar to match. I also will try those 230a 200v alternate mosfets Paul mentioned.
