the issue of Oil contamination from steam blow by would most likely be solved/helped by tighter piston rings or even a vacuum pump on the crank case with a seperator. That is if it is an issue.
If there is an issue with how easily the water boils alcohol could be added as ethanol boils at 78C and water boils as 100C you could drop the temp some what.
 I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
