Originally Posted by XJguy
Correct....in fact in the Hybrid version of the GMC Yukon, you will see that it uses extensions on the rear pillar and sharper profiled tail lamps to promote clean separation.....its a slight difference that the casual observer may not even notice. The regular Yukon is rounder.
But don't forget in your application you have vents/flaps where the tail lights normally are that feeds air into where the potential turbulent wake would be.....so I don't think its really an issue for you....again this can be tested using tufts.
It really is too bad that they don't allow for smooth under-bodies and rear diffusers...you would have a venerable guided missile if they did.
Ok I will leave these for now then, thanks for the info.
Really finding aerodynamics very interesting, bought a few books on it which I am reading at moment.
Well as for the smooth under-bodies, we can have a belly pan, and there is a flat pan under the greabox area too. I will try to find a photo...
Found a photo. Its a crach of another car but gives an idea of the underside.
