Old 06-27-2010, 12:13 AM   #7 (permalink)
Olympiadis
oldschool
Olympiadis's Avatar
White2003Focus - '03 Ford Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 Chevy S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Dodge Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 Chevy C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Chevy Irocz LB9
Last 3: 30.14 mpg (US)
1999 C5 Corvette - '99 Chevy Corvette
2008 Infinity G37 - '08 Infinity G37
Originally Posted by trikkonceptz View Post
It's seems obvious to me, but in order to begin raising MPG's in your line of cars, (Insert Brand Here), why not implement and engine cut off like the hybrids do when idling?
I have to imagine that a change like that alone can have a significant impact on the MPG's of any vehicle. Now to go along with that some design changes would have to be made like an electric a/c system, but that already exists, so what am I missing?
I think if all the cars at an intersection were to shut off and sit silently while we wait for lights to change the impact would be incredible .. not to mention automakers could boast about a bump in MPG's to stay ahead of government regulations.
I'm sure it would have been implemented earlier if not for several important factors.
Pre-OBD2 cranking strategy involves quite a bit of extra fuel.
First, I think if some of you saw the "Cranking Fuel" table you would probably have a cow. Some of them are factory calibrated to go 40% richer or more, depending on the coolant temperature.
Once cranked, there is something called "After-Start Fuel" or "Time-Out Fuel" which can start you out at an 11.0:1 AFR, and ramp you up to stoich over a period of seconds or minutes, depending again on temperature. This time period is called the "Time Out". After that there is often "Warm-Up Enrichment" or sometimes called "AFR vs LD vs ECT" which is just a name for a 3-D fueling table that adjusts the AFR based on coolant temp and load.
There was often a significant "time-out" period for going into closed-loop mode after certain other qualifications were met by the sensor feed back.
In my experience, the larger the engine, the larger the % of cranking fuel is skewed to the richer AFR. It's not proportional to the engine size.
When I tune an OBD1 system I reduce these fuel enrichment tables drastically until I find the limit of operation. Engines with aluminum heads, cold-air intakes, unrestricted exhaust and/or headers, low static compression, or the use of fuel diluted with alcohol, will all require some extra cranking fuel, and after-start fuel.
Newer OBD2 strategy still uses some of this extra fueling on some models, though it is much less than before, and the system goes into closed-loop mode very quickly in comparison.
There is still going to be a trade-off there, and if you kill the engine while sitting at a stop for less than 20 or 30 seconds, then you'll probably come out on the losing end of the equation.
As far as non-hybrid cars go, if everyone was killing their engines at stop-lights there would probably be a multitude of other problems created along with increased traffic congestion, which could easily negate the fuel savings IMO. The way I see it, there are already way too many people with delayed reactions when taking off from stoplights, due to distractions like texting, or just plain being oblivious to their surroundings. If you end up having to sit through two or more lights because of the delays, you will still have to start your vehicle to move up in the line.
Using electric mode for these short stop-n-go's is the ideal way to deal with the situation, at least IMO.
I don't have electric, so my preferred way is to go into the calibration (tune) and lower the idle speed, especially the "Idle in P/N" (park/neutral), and when possible use open-loop idle when available. In open-loop you can command a leaner AFR. You can get away with extremely lean AFR when in park or neutral.
Also, since you mentioned government regulation, how about we just get rid of at least 60% of the traffic lights out there? More and more go up every day.
