Old 06-27-2010, 01:37 PM   #8 (permalink)
redline5th
Honda Ecomodder
redline5th's Avatar
The Civic - '98 Honda Civic DX
90 day: 41.59 mpg (US)
It's just the way they're made... that's the maximum it is safe to run them at. More expensive tires would probably be safe to run at a higher PSI.
Just remember that the PSI increases roughly 3-4psi when you start driving as they warm up. Heat causes expansion.
http://thechriscoleman.com/
Alas.... no more 40mpg -- Now B18C swapped.
