Originally Posted by SVOboy
You did plug your antenna back in, right?
Yes I did! The problem is that the antenna is snapped off, and it was repaired once, and that snapped off... leaving me with no hole to put a hanger down. I was able to pull in stations to program (automatically) by touching a length of wire to the nub that is left, and I got the rest manually. The problem isn't when I am sitting in front of my house, it's when I start moving. I guess maybe I should start in a junk yard looking for a "new" antenna, see what the improvement is and go from there.
So nobody has experience with the "antenna signal boosters"?
